help me with PAC SOEM?
  • 2
Predd
hey everyone! im trying to get my system to work with my factory amp. ive seen a lot of posts on the PAC SOEMs but most are running factory HU or the RCA option. long story short, i bought everything i needed for a decent system without the knowledge that the bose factory amp/speakers in my car were a major hassle.. i tried to install and failed, getting power on the HU, but no sound. shops have gave me estimates of 200+ to install everything(even after ive ran all the wires). this last shop i went to, the owner gave me a PAC SOEM-4 and said that this would trigger the factory amp to turn on and my speakers will work? or something around that area..
well, i have no idea what this thing is.... i know a little about car audio, but i would still say im a newbie. so all these wires are a little intimidating. the owner tried to explain it to me in the 20 mins i was at the shop but it mostly went over my head.
the owner said i should run both sides wired. i have the factory harness and the aftermarket harness. do i just wire the factory harness into output and the aftermarket harness into input? everything color to color? and there are so many ground wires.. what do i do with them all? im confused.. can anyone plz help me out? that would be great.. thank you.
'98 Acura CL 3.0
Pioneer AVH-X2600BT
Google search the wiring schematic to the pac you have. Should be a power work for constant 12v, ground, and remote on. Then you need to run one channel off the pac, speaker, positive and negative to a factory speaker. Splice that in. Once you do it, it will work one rca. May need to splice in for more channels or rcas. It is simple but a ***** though when you first attempt it.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
527
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
550
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
5
619
Predd
Predd
Vallejo,CA
blobb454
