Help me out, midbass or sub??
  • 3
v6camaro00
st. louis
In the process of rebuilding my entire system in my camaro which consist of 3 sets of speakers. 6 1/2" in the front door, 6 1/2" woofer/midbass in mid panel, and 4" in rear hatch. i've got infinity 62.7i's in the door and infinity 42.7i in the hatch all thats left is the blown 6 1/2 woofers. Should i replace these or buy a sub and amp? to replace the speakers would be about $160 and the amp and sub would be about $400. The amp would be a kicker zx750.1 and the sub will either be a re se10 or a fi ssd 10".
By 'mid panel' I assume you mean the panels to the sides of the back seats? If so, those are 'rear' speakers, and can be ignored assuming you build an adequately strong front stage. I vote buy the sub (nice sub choices btw), upgrade the rear-fill with cheapy speakers later if you want.
there called sail panel speakers and only put out lows. so either a mid or sub has to go there unless you take the wire from the rear hatch speaker and put a component set in there.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
475
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
533
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
564
v6camaro00
v6camaro00
st. louis
v6camaro00
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
