Help! Loud hum in tweeters and mids!
  • 4
C1500martin
Cali
So I installed everything and I have a LOUD hum in my tweeters and mids I'm running them active. Off a soundqubed 4-120. I have the red output TVA into channel 1, and the white into channel 3. Do I need y splitters? But wtf is this loud hum!?!?
Where is your ground located? Does both amps lead to the same ground? Did you put a filter on your tweeter or is it set to full range?
Both my grounds lead to my second battery and that's the weird thing my sub doesn't do it only mids and tweeters plus I got a horrible engine whine as well. Text me I reset my phone and lost your number
if you got a horrible engine whine everytime you press the gas pedal, that's definitely ground loop issue.. I think both your amps and 2nd battery need to ground to full chassis.. That's how I have mine..
Turn the gain down.
I completely turn the gain down like as down as it goes and it still makes the noise
---------- Post added at 10:33 PM ---------- Previous post was at 10:33 PM ----------
How can i test if its my rcas pr headunit or amp?
You need to run your grounds to the vehicle Frame as well as the battery.I run 0 ga to the frame back up to a distro block for grounding.Got the Big3 done??
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
89
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
129
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
239
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
712
C1500martin
C1500martin
Cali
audiobaun
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
