Help going crazy :)
  • 3
Yankees27
I have a 2003 Dodge Durango and I decided to put a Pioneer Avx-P7000CD with the Avm-P7000R brain. It is all hooked up. but I keep getting a message that says cant use while driving. The parking brake is on and car is in park. I can get audio but nothing else. The wires were cut from Durango side and I cant get memory to stay on either. There are two pink with black wires which I am not sure of either. Any help is greatly appreciated.
Not trying to insult your intellegence, but did you hook the green parking wire from the HU into the e-brake wire on the vehicle? Some people attempt to bypass this by grounding it directly but Pioneer requires adelayed ground which means it cant ground until after the unit has powered up. As for finding a constant, your best bet is to get a DMM and test. Constant 12V are generally a lower guage than the other wires so it should narrow it down some.
The parking brake can be bypassed by using a relay hooked to ground and the blue amp power wire. There are numerous videos online that show how it can be done.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
129
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
438
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
416
Yankees27
Yankees27
North Carolina
fomoco365
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
