Help deciding on which 6.5 component to use
mbss
I am building a new system and would like to know some opinions on the two component sets I have narrowed down to. I listen to mostly heavy metal and hard rock, but also listened to other genres as well. I need the set to have a punchy, quick, and articulate midbass response that is powerful. Moreover, I would prefer the highs to not be ear piercing but detailed. The two sets I am considering are:
Image dynamics CTX65cs
DLS RM6.2
I was also considering the ID CXS62 chameleons, but they are a little out of my price range. I do not have a DLS dealer anywhere nearby so anyone with experience please present your opinions.
Thank you.
-Side note: I am also considering the Phoenix Gold Rsd65cs
I read through all the responses....thank you. I would still appreciate an opinion on the DLS performance as compared to the Image Dynamics set.
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
207
475
461
mbss
mbss
Kenosha, WI
CL1CKCLACK
