• 5
no coil rub and i looked at all of the solder and didnt seem bad to me looked good how much dose the recones run .do u know? and thanks.
depends if you wanna do it yourself or send it in for him to do it. Idk what he charges for a recone if he sends it to you you'll have to ask him. If he doesn't have the dustcaps for the HX2's i would hit up dave @ PSI and see what he can do for you
when selecting a battery for a system that will be ran when the car is running, you want a battery with a very low ESR .
i don't recommend using a system of this caliber with the car off ever unless you want to but 12 huge deep cycle batteries and you can charge it for 24 hours after play..
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
464
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
531
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
562
aaronwhitlock3
Hodgenville, KY
Papermaker85
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
