headlights dimming on my 2011 hyundai elantra...need advice on what to do next??
  • 3
dizz10dizz
Alright guys, i have a 2011 hyundai elantra limited and here is everything i did to it.
Alternator has power rating of 90 amps
Ran 2 gauge power and ground wires with a xxx 2 farad capacitor.
I have a RE MX 18" 2 ohm DVC and it is wired at 4 ohms right now and its 1500 rms.
18" Competition subwoofer
Dual 2 ohm voice coils
3000 watts peak
1,500 watts RMS rated
A concept cd-2410 that is:
RMS Power 600W x 1 @ 4 Ohm
RMS Power 1150W x 1 @ 2 Ohm
RMS Power 2410W x 1 @ 1 Ohm
Signal-to-noise ratio: 95 dB
Frequency Response: 5Hz - 250Hz
Total harmonic distortion: 0.1%
with the gain all the way down it still dims my headlights pretty bad even at 4 ohm
My question is what should i do next? I plan on doing the Big 3 and either want to rebuild my alternator to a higher amperage or get a dry cell battery to put in the trunk...What do you guys think my next move should be? Should i just abandon my RE and get a smaller sub and call it quits?? Any advice appreciated.
Thanks
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
Big 3 will not help dimming. Big 3 helps get more power to your amp, which is the opposite of what you want to reduce dimming. Either add lifepo4...
6
658
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
8
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
454
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
dizz10dizz
dizz10dizz
Paw Paw, IL
gckless
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
