head unit starts up but no sound!
  • 4
ynottony93
today i was installing my amp and subs to my stock nissan xterra headunit and everything was going good untill i accidently touched one of the sub wires to the ground on the amp there was sparks and then after that there's no sounds from any speakers.. i unpluged everything and put it back to stock and still no sound any help would be much appreciated //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
it's a stock nissan cy130 i checked the fuse in the hood and in the dash they're all good
Once i had the same problem and it was the wiring, I had no sound but hissing. => smthing tells me u did not wire it properly.
378
687
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
752
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
923
ynottony93
ynottony93
Houston, tx
Rookie_80
maylar
    Jun 2, 2024
    Jun 1, 2024
