Ground
  • 1
Bass so loud it HZ
CarAudio.com Regular
I'm going to redo my grounds this weekend and wanting to know if my plan will be sufficient.i have one 4/0 cable I'm going to run from frame up through floor to a homemade distribution block .it is solid aluminum with holes drilled in the side and set screw on top. then I plan to run alteast 3 2/0 to my surge 10k then prolly 3 2/0 to my 120 ah cmax bank ...will that work ? I was originally gonna use a 2/0 from frame to block but found the 4/0 and figured that would be better.i currently have runs going to seat bolts and they have worked good but wanting to do it correctly.. thanks in advance!!
Single ground. If there is one thing car audio proves it's that the saying "Ground is ground the world round" is complete BS.
4
288
I'm guessing that's what it is. There's not a lot of room back there.
12
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
3K
Yeah I saw a lot of that when doing those installs as we also did surround sound system wiring as well. I always ended up being the doing it as...
11
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Bass so loud it HZ
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
