Ground loop issue
  • 3
JohnPD
CarAudio.com Regular
I’ve tried all of the suggested fixes in the sticky thread, so I’m going to try the ground loop isolator. I’ve got a very slight buzz just from the tweeters in my component speakers. I’ve changed and checked everything and all is good. Where do I hook these things up to? Back of the head unit, or at the amp?
I'd use the isolator as close to the amp as possible. That said 9 times out of 10 a ground wire (~14awg) run between the amp ground and the HU or pico fuse fix (see pic) will resolve a ground loop. If you have outboard comps, try moving the crossovers.
How do I run a ground wire from the amps ground to the head unit? Where do I ground it on the head unit? Tap into the existing head unit ground that’s on the wiring harness?
If this is in the sticky I’m sorry but if you haven’t tried grounding the hu frame to the metal in front of it in your dash, that’s a good idea.
Single ground. If there is one thing car audio proves it's that the saying "Ground is ground the world round" is complete BS.
4
412
I'm guessing that's what it is. There's not a lot of room back there.
12
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
3K
JohnPD
JohnPD
Ravenna, Ohio
2023 LTZ
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
