Good sub to replace my burned up Alpine SWR-12D4 Type-R?
  • 3
hutt132
US
I have a JBL GTO 1001 1000-Watt amp and a ported 2.5cu ft. box tuned to 34Hz. I forgot to turn the volume down on my phone (I have to keep it 4 notches down or else it distorts the audio) and when I started playing music it burned up the voice coils in my subwoofer because the volume was too loud.
The Alpine SWR-12D4 Type-R is online Amazon for $140, and I was wondering if there is a better sub I could get for around $200, or if I should just buy another Alpine.
American bass xfl, soundqubed hds300, both are a lot more durable then the type R. You might need to learn how to set your amp gains and headunit settings properly because any sub will die from heavy clipping.
I'm sure I set the gain properly; the problem today was that I had my head unit at the "max" volume I typically listen to my music at, but I forgot to turn my phone's volume down four notches, which caused the sub to burn up within a minute.
I looked at the American Bass XFL1244 for $175 on Amazon and it looks nice. I'm going to look a little more into it and maybe purchase it.
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
4
159
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
523
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
555
hutt132
hutt132
US
Jeffdachef
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
