Good amp for a JL 10w3v3.8 8 ohm sub
  • 5
Well since it's 8 ohm then you want to stay away from monoblocks as they don't exactly make a whole lotta anything at that high of an impedance. Get a normal 2 channel 2-ohm stable per channel class AB amp and bridge it. Since the amp will still only supposed to output half the power because it's an 8 ohm sub then just get anything that does 200 watts per channel or more at 4 ohms stereo, it'll run cooler too because it'll be an "easy" load. Crunch GP series is good and cheap.
121
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
322
6
456
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
746
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
543
bigaudiofanatic
Dynamic Mobile Audio
bigaudiofanatic
Dover DE
mclerico83
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
