GM cs144 alt on a Honda CR-V?
  • 6
bumpincrv
Illiniois
I was told that a Gm alt cs144 will fit on a 1998-2000 Honda 4cyl models, is anybody running this or know of anybody that is? Just need to know what needs to be done wireing wise and alt case and front housing and what i will have to do with that to get it mounted
im not sure if its deffinatly the cs144 case , i was just sayin check into it ill ask my buddy tho , what motor is in your crv? and pics of stock alt, im off this week and part of next, ill look into it again......
ok itll atleast give me somethin to go off...
edit: i did find both pics ya gotta find someone with one and just try and mount it , you will need the v belt pulley i believe tho if the pic of yours i found is right....... its not that far off tho from the one you got.......
and does your brother still have his alt? see about that one too ......
ya just gotta try, everythings custom when it comes to alts usually..... ya just find whats close and make it fit or pay out the ass for one that does......
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
528
$500 is not unreasonable, but just know about alternator shopping: There are two numbers that matter: The amp output at or near idle (what's it...
7
887
bumpincrv
bumpincrv
Illiniois
yunvme666
