SOLD FS: Unfinished fiberglass enclosures - make me an offer!
killa101
Michigan
I got a couple of unfinished fiberglass enclosures for sale. The fiberglass and all that is done they just need some sanding and body filler work until they are ready to paint. These were enclosures originally made for customers but the customers didn't end up paying so they were not finished. Instead of dumping more money into them to finish them up I'm just going to sell them. They will take a little work but you will get a fiberglass enclosure at a cheaper price.
The first one was made for three 12" subs. This needs a little bit of sanding and body filler before it is ready for paint. It is about 3.4 cubic foot.
The next one is a ported enclosure for two 15" subs. There is also a spot for an amp on the front of the enclosure. This enclosure was designed for a 2003 Mitsubishi Eclipse but I believe the trunk is the same for some of the other year Eclipses. The subs are positioned so they can be seen from the rear hatch window. The enclosure is about 3.5 cubic foot and has two 4" ports. There are aeroport flares fiberglassed into the enclosure there is not any additional port so you can tune it to your desired frequency.
I don't really know what to sell these for so make me an offer. I will say $500 but I will take the best offer. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Let me know if you need measurements of the enclosures or want more pictures.
free bump, good luck with sale, hope you get something back for your work //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Specifications:
Built for three 12" subs
Internal volume: Approximately 3.4 cubic foot (single chamber)
Enclosure configuration: Sealed (common chamber design)
Outermost dimensions (approx.): 38" wide x 25" deep x 17" tall
Subwoofer outer max dimension: 12 3/4"
Subwoofer cut-out dimension: 11 3/8"
2 15"s in 3.5 cf ported will slam. Is that net or gross?
gross.
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
6
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
Yeah. Same thing here. The under seat box I did for the 8s was 325$. He’d already wasted that much with 2 prefabs that sounded like ass.
6
killa101
killa101
Michigan
killa101
1aespinoza
    May 23, 2024
Doxquzme
    May 22, 2024
