FS: Sundown Audio 4500D Mint (vid)
  • 3
Anotherguy
Va
Sundown Audio 4500d
Perfect. Probably about an hour play time. No scratches, not even on the feet. It was powered by a 250 amp alt and 4 D3100's. I'm a Sundown rep, so no worries.
Rated power output
----RMS power, 2 ohm linkable/dual mono
9000W x 1CH ----RMS power, 1 ohm mono
4500W x 1CH ----RMS power, 2 ohm mono 2000W x 1CH ----RMS power, 4 ohm mono
900W x 1CH Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~50Hz Bass boost @ 45Hz 0~9dB Phase shift control 0~180 degree Frequency response 10Hz~250Hz (+/- 1dB) T.H.D @ 4 ohm
$1050 plus actual shipping. Local pick up is welcome, I'm in Morrisville NC 27560
Actual shipping
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
12
Some of the NVX stuff seems alright, but the amps, especially the higher end ones, they seem suspect and sometimes show stats that straight up say...
13
5K
Anotherguy
Anotherguy
Va
steven_escalera
