FS: Stetsom 800.4 BNIB
  • 1
Skip01
Diggy
7,339
Marrero,LA
1. Product:
Stetsom Venom 800.4 4ch
2. Specs:
Number of Channels 4
RMS Power at 2 Ohm 13.8V 4x200 Watts RMS
RMS Power at 4 Ohm 13.8V 4x140 Watts RMS
Power @ 13.8V Bridge 4 Ohms 2x400 Watts RMS
Supply Voltage 9 a 15 V
Frequency Response 20 Hz a 22 KHz
Crossover Low Pass 40 Hz a 700 Hz
Crossover High Pass 70 Hz a 700 Hz
Signal to Noise > 90 dB
Harmonic Distortion
Input Sensitivity 0,2 V
Input Impedance 15K Ohms
Impedance Output 2 Ohms
Consumption with Signal Musical 40 A
Consumption with Signal Bass 70 A
Dimensions (H x W x D) mm 40x240x230 mm
Weight Kg 1,8 Kg
3. Description/Condition:
BNIB...still shrink wrapped in box
4. Price: :
$350 shipped
5. Pictures:
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
I have no experience with them, but it does not look half bad for it's price. Big plus if you can set all features via cell phone. If you do pull...
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG.16,2022 @9PM CT. THANKS
12
Skip01
Diggy
Skip01
Marrero,LA
Skip01
