FS: Stetsom 1k6es BNIB
  • 4
Skip01
Diggy
7,339
Marrero,LA
1. Product:
Stetsom 1k6 ES 1ohm
2. Specs:
Number of Channels 1
RMS Power at 1 Ohm 12.6V 1600 Watts RMS
RMS Power at 2 Ohm 12.6V 820 Watts RMS
RMS Power at 1 Ohm 13.8V 1780 Watts RMS
RMS Power at 2 Ohm 13.8V 1035 Watts RMS
Supply Voltage 9 a 15V
Frequency Response 20 Hz a 10 KHz
Crossover Low Pass 50 a 10 KHz
Signal to Noise > 90 dB
Harmonic Distortion
Input Sensitivity 0,2V
Input Impedance 1 Ohm
Impedance Output 1 Ohm
Consumption with Signal Musical 1,7A à 77A
Consumption with Signal Bass 1,7A à 154A
Dimensions (H x W x D) mm 75 x 310 x 170
Weight Kg 2,2 Kg
3. Description/Condition:
BNIB...still shrink wrapped inside box
4. Price: :
$315 shipped
NO TRADES
5. Pictures:
Yeh if this wasnt bnib id send it too a buddy to be tested throughly...im skeptical of the bigger ones...but the technology is there...they boards are totally different than what most are used too.
All voltage and less amps to make the power
Ive been trying to find someone who has run these amps to see if they are all they claim.
The only disadvantage the stetsom amps have is the noisy fans. I know someone with two 14K amps and they are noisy as hell but put out a crap load of power. I'm sure they do everything they are rated at and if not more.
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
I have no experience with them, but it does not look half bad for it's price. Big plus if you can set all features via cell phone. If you do pull...
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG.16,2022 @9PM CT. THANKS
12
Skip01
Diggy
Skip01
Marrero,LA
Mass Car Audio
