Orion 8004 in like new condition (chrome finish) for $300 shipped. Pics coming tonight or tomorrow when I get home. I love this amp for my comps, but could use the money more than the amp right now.
Features:
Intelli Bass variable bass equalization (models 4004, 8004)
Intelli Q bass optimization circuit and remote gain option (model 7005 only)
2-way variable crossovers and high-level inputs (model 4004)
Separately adjustable, variable 2-way active crossovers with proprietary Copy/Master control circuit for RCA outputs (models 8004, 7005)
Copy/Master feature supports high-pass, low-pass, or bandpass configuration and gain matching for multiple amp systems
Selectable 2/4 channel input (model 7005 features 2/4/6 channel selectable input)
12/24 dB/octave variable low-pass filter (channel 5) and remote gain option
Heavy gauge direct-wire high current satin finish power and speaker terminals
Specifications:
Power Output:
4 x 100W @ 4 Ohms
4 x 200W @ 2 Ohms
2 x 400W @ 4 Ohms
Signal Processing:
Variable Low-Pass 20Hz to 3kHZ
16dB of boost with INTELLi Bass
>Selectable AUX out
Fuse Size: (1) 100 MAXI
Dimensions: 23.9" x 10.5" x 2.3" (607mm x 267mm x 58mm)
Features:
Specifications:
Power Output:
4 x 100W @ 4 Ohms
4 x 200W @ 2 Ohms
2 x 400W @ 4 Ohms
Signal Processing:
>Selectable AUX out
