FS: Mpyre 65M mids/crossovers
  • 6
bergend2
Milwaukee
Pair of Mpyre 65M midrange speakers, and crossovers (not in picture, but included)
Used, but in good shape. Just picked these up recently, and was going to use them in my Jetta, however it was more work than I was looking to do to mount them in my doors, as they are slightly larger than a normal 6.5" speaker, they are ~7". So I am sticking with my ID OEMs instead. The only problem is that one of the tabs on the speakers is partially broken off, check out the picture.
Mpyre 65m specs:
Fs: 25.7 Hz
Qms: 6.2
Qes: 0.46
Qts: 0.42
Vas: 11.7 liters
Re: 3.25 Ohms
Le: .214 mH
BL: 9.7 N/A
Mms: 76.7 grams
Sd: 130 cm^2
Cms: 0.5 mm/N
Xmax: 14mm 1 WAY LINEAR
Xmech: 18mm 1 WAY MAX
Depth: 3 5/8"
PWR Handling: 150WRMS
Single 4 Ohm Voice Coil
$90 shipped.
Trade for a set of Memphis MSync 6.5" components? I have them listed for $150. Would take a loss on them to test with these.
Thanks for the offer, but I don't have any use for more components right now.
I thought you just said you were trying to put these in your doors? It's the same thing.. a midrange w/no tweeter. Just like these.
edit: My bad. I skimmed and didn't see your post about your ID OEMs.
Yeah, sorry man. Got a few sets of OEMs, and a bunch of Eclipse comps around here as well. Those MSync's are nice though, I had the old ones with the CF cone and blue tweets, and like them a lot.
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
I agree with DJ. Pro style speakers are designed for large ported enclosures and lack bottom end without an enclosure. Plus they tend to suffer...
8
I think you need like a 10x switch on an amp? You would need to bandpass the mids or something Pioneer network mode or similar? I know the new...
I have ran the 6.5’s, but not the tweeters. They were very smooth and had good low mid bass. They were perfectly happy being high passed at 75 hz...
bergend2
bergend2
Milwaukee
m3dia_lab
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
