FS-Massive Nano N4 Monoblock Amplifier
  • 4
mfenske
aemracerex =POS
Massive Nano N4 Mono Amplifier
Used. Original owner (not me) must have been a bit of a hack because cosmetically it's probably 6 or 7 out of 10 but it works great. Rated at 2k at 1 ohm I've run anything from a SD E-8 to an Eclipse SW-9182 with it. Missing the regular power screw on the ground terminal so there's a cap screw in its place. Mounting fins a bit bent and there's some 3M double sided foam adhesive residue on it.
185 shipped to lower 48 including paypal
Free bump for being one of few classified ads that follow the rules //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
The tape residue might come off with a plastic scraper and rubbing alcohol.
  • Locked
Hello all, I am new to this forum but have had no luck on ebay/gumtree/fbmarketplace regarding trying to shift my aftermarket car audio setup. My...
  • Locked
hello mate, text me +1 (706) 300 5660 for quick response, if you need the Massive audio 15" dmx stage 2 for sale at a secondhand price, stay safe
3K
It only works if you send rca signal through it to your amps.
6
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
mfenske
aemracerex =POS
mfenske
Portland, Oregon
mfenske
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
