jfa1177 10+ year member
white bread
I have for sale a really clean JBL BPX500.1 amp. This is one of the famous mono amps developed in unison with Crown.
The specs are as follows:
RMS Power Output:
4 Ohms: 237 watts x 2 chan.
1 Ohms: 674 watts x 1 chan.
4 Ohms Bridged: 718 watts x 1 chan.
Unused dash mounted gain control
Full MOSFET Power Supply
Variable High-Pass / Low-Pass crossover (32-320 Hz)
Selectable Crossover Slope (12 / 24 dB)
Bridgeable: double the voltage from one channel into impedances between 2 and 4 ohms - use parallel wiring to double the current from one channel at 1 ohm.
Dynamic Bass Optimization (DBO) Subsonic Filter
Preamp Outputs
CEA-2006 Compliant
S/N Ratio: 66.4 dB
Dimensions: 12-1/4" L x 13" W x 2-9/16" H
It is a refurb but I got it from JBL directly. It comes with the amp, original packaging, fuses, screws, sticker,and manual. It also has a 1 YEAR WARRANTY
looking to get $150 shipped for this power house.
RMS Power Output:
Preamp Outputs
CEA-2006 Compliant
S/N Ratio: 66.4 dB
