SOLD FS: Hifonics Brutus 1606D
  • 1
2loud4youmorris
1. Product:
Hifonics Brutus 1606D Monoblock Amplifier
2. Specs:
RMS @ 4-Ohm: 1 x 550-Watt
RMS @ 2-Ohm: 1 x 1100-Watt
RMS @ 1-Ohm: 1 x 1600-Watt
Hifonics New Illuminated Heat-Sink Design With Blue LED Light Pumps
Hifonics Blue Illuminated Logo
Maxxsonics Illuminated "M" End Panel Logo
Heavy-Duty Ultra-Fi™ MOSFETS
Highly Efficient Super D-Class Amplifier Circuitry With Oversized MOSFET Output
Fully Adjustable Accu-Cross™ Crossovers
±18dB Variable Bass Equalization @ 45Hz
180° Variable Phase Control (15 to 35Hz)
Dash-Mountable Bass Remote Control Included
Variable 24dB Subsonic Filter
Brutus Pulse Wave Modulated MOSFET EXVP (Exponential Vari-Power Supply)
Twin-Turbo Torroid Coil Design
HSMD Hifonics Surface Mount Design
Balance Line Inputs for our 18-Volt Line Drivers
RCA Line Output for Amplifier Daisy Chaining
Gold Oversized 2-Gauge Power Connectors
Power From The Gods Included
3. Description/Condition:
Used but still in good.
The fuses were blown when I got it.
I replace the Fuses with 100amp ones.
The cases wouldn't fit in so I took the cases off and just put the fuses in there and electrical tapped the fuses.
Works great.
8.5/10 cosmetically
9/10 Mechanically because its used
4. Price: :
185 Shipped
5. Pictures:
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
2loud4youmorris
2loud4youmorris
Caro, Michigan
2loud4youmorris
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
