SOLD FS: FUSION FJL-1611D 1600wrms CHEAP
Cmccloud
I have a used Fusion FJL-1611d. For some reason it works great on a 4 ohm load but once I wire it to a 1 ohm it won't work right and goes into protect. If someone wants a high power amp, high dollar amp(sells for $999) then this is the deal for you.
Fusion 1 Channel D-Class Linkable Amplifier CEA 2006 Rated FJL-1611D
Part #: FJL-1611D
Your Price Qty
$999.99
Detailed Description
1 Ohm / 2 Ohm Stable Linked
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated Audio Input and Output Connections
Gold Plated RCA Output for Multi-purpose installations
F-BASS Remote Controller Compatiable
Product Specifications
Bandwidth 10Hz - 50kHz
Signal to Noise >:95dB
Fuse Rating 4 x 30A
Separation >:60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz - 240Hz @ 24 dB / octave
HP Variable Crossover 40 Hz - 240Hz @ 24 dB / octave
Variable Bass Boost 0dB + - 18dB Gain @ 45 Hz
Variable Sub Sonic Filter 10 Hz - 55Hz @ 18dB / octave
Input Impedance 20K
Damping Factor >:200
T.H.D 0.06%
Dimensions D 65.5mm L 468mm H 276mm
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
600 WRMS per Channel @ 4 Ohms and 1% THD+N
900 WRMS per Channel @ 2 Ohms and 1% THD+N
1250 WRMS Bridged Channels @ 4 Ohms and 1% THD+N
14.4 Volt Power Output Specifications
840 WRMS per Channel @ 4 Ohms and 1% THD+N
1250 WRMS per Channel @ 2 Ohms and 1% THD+N
1600 WRMS Bridged Channels @ 4 Ohms and 1% THD+N
Linked Power Ratings @ 14.4VDC
2850 Watts RMS Linked @ 4 Ohms
3400 Watts RMS Linked @ 2 Ohms
150 shipped
give me this amp and 120 bucks and ill send you my like new in box crystal cad600.2T
150X2 4ohm
300X2 2ohm
600X2 1ohm
1200X1 2ohm
mint and people can vouch for how clean it is cosmetically and underrated in power...
I was thinking the cost verses the price of a new subwoofer wouldnt be worth the effort. Fusion Audio wasnt a very well made brand of audio in general
5
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
Well I finally had a chance to hook up the us acoustics amp. What a difference. Still playing around with the 13 band equilizer. The h/u put out...
12
Cmccloud
Cmccloud
LaFollette, TN
rusty_armadillo
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
