Fs: Cheap batts!!!***
michaellane
tx
Great second batts! had a good amount of PM's here and caco so I picked up some more. I have 14 left as of right now
2. Specs:
26ah rating
7" long x 6.5" wide x 5.2" to top of tabs (rounded up a tiny bit)
Totally sealed and non-spillable AGM technology
40% higher ah rating than a Kinetik HC600
This will make a great secondary battery for mid size systems that need a little extra reserve power for when the alt just can't quite keep up
3. Description/Condition:
only opened for testing
4. Price: :
$45.00 shipped trades or anything need to be sent via PM
Anyone know a rough guess of how many cold cranking amps these have? I'm thinking about replacing my stock under the hood battery with two of these in a Nissan Titan. I read somewhere to multiply the ah rating by 7.25, but that only gives me 188CCA per battery. I would think it's much higher than that though considering a Kinetic HC600 has 600ca
I wouldnt put these under your hood. Thats my honest opinion that I tell everyone. I coukdnt even say that they will survive the heat. Anyone who has bought then uses then as secondary batts and thats what I recommend. For all I know the case might melt under the hood depending where located in some cars. If anyone has questions like this just shoot me a message . I also dont see that formula being too accurate. Find another battery and do the math to see if its right. The hc600 has like 16ah ehich wouldnt gove you 600ca.
---------- Post added at 10:20 PM ---------- Previous post was at 10:20 PM ----------
All messages replied
The Kinetic HC600 has 18 ah and 600 cranking amps (according to soniceletronix) , but batteries are made differently. Like Optima yellow tops have way lower CA than Optima red tops.
Would this be a good 2nd battery for a 1800w System... Lights Dimmed on me with a 500w RF Prime Amp.
2010 Dodge Charger V6
140 Amp Alt. OEM
750 CCA Battery OEM
Big 3 Done...
My first install on my vehicle was in '94 right before I turned 18 😂 I'd "helped" on a few starting at 16 but my helping was mainly gofer work...
19
3K
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
Starting from scratch don't have an amp yet gonna wait till I make a decision on which subs right now I'm just trying to settle on which subs I'm...
5
michaellane
michaellane
tx
big scott
Decebal
    Jun 10, 2024
