FS Audiobahn A18001DT
Austinw88
Audiobahn A18001DT
In almost perfect condition, Has some slight scratches on it from being wiped off with a cloth. No big scratches. all terminal screws are good and there.
Has dual fans and volt meter along with a not very accurate clipping meter.
3600W Max, Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 600 watts x 1 chan.
2 ohms: 1200 watts x 1 chan.
1 ohm: 1800 watts x 1 chan.
Max Power Output: 3600 watts @ 1 ohm
4-way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
Cobalt Blue LED Illuminated heat sink design (on/off switch for your preference)
Large Digital Volt-meter Display
Preamp outputs
Dual Cooling Fans
Chrome Flame Cooling Fan Grill covers included (other optional designs available and sold separately)
Multi-Stranded Power Supply Toroids
Double Sided Glass Epoxy Circuit Board
High gloss chrome plated finish
Variable Bass Boost: 0-18dB at 40-100Hz
Variable Low-Pass Crossover: 50-150Hz
Variable Subsonic Filter: 15-40Hz
Frequency Response: 15-150Hz
THD: 0.05%
Variable Phase Control: 0 or 180°
Dimensions: 16-7/8"L x 11-15/16"W x 2-1/2"H
200 OBO
on me
IMG_20140106_214954_307_zpsmo2is0ct.jpg'%20alt='IMG_20140106_214954_307_zpsmo2is0ct.jpg'>
These amps are actually pretty strong and have a lot more balls than most people will give them credit for. Audiobahn seems to get a bad rep for all the chrome and flames but they did make some decent equipment and this is a good example of it right here. Good luck with your sale
thanks man, its a strong little amp. sure you don't need it? lol
What is it stable to? Power hungry? Trying to find a cheaper amp til I can afford new one. What kinda actual rms?
1 ohm stable. not really power hungry did fine on a stock alt and 2 small batteries.
I've heard of people running these at .5 on super strong electrical but I wouldn't recommend it personally. as far as actual RMS I don't know but I have read they do close to rated at 14.4v no proof tho. I can work with you on the price if you're interested.
I had one of these not long ago. That's how I know she's a winner. Pretty content with my SQ 2200 right now otherwise I would take it off your hands. I wouldn't doubt you'd see 1700-1800 out of these with the juice to back them
FYI.. These are not a Car shaking sub.. But these will give you some pretty nice bass in almost any vehicle that has nothing at all. Best placed...
5
Austinw88
Austinw88
South Carolina
Austinw88
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
