SOLD FS: 2 Image Dynamics 10" subs and Alphasonik 4 channel amp 160 x 4 or 960 x 2 $500
randyrsx
I've been running this setup for almost two years in my RSX. The two boxes fit perfectly snug between the rear wheels and are easily removable for large items. Price includes PP fees and shipping.
Providing a balance of high output capability combined with unrivaled sound quality is their driving force behind building the best performing speakers in the world. Simply put Image Dynamics Speakers and Subwoofers are the choice of the sound enthusiast. Their performance is the result of a unique design philosophy and applied engineering science providing unique speakers and subwoofers that truly perform.
The IDQ V.2 continues to increase upon the unsurpassed competition success of the original IDQ subwoofers with increased SPL output and significantly smaller enclosure requirements. The all dual voice coil IDQ V.2 series have increased excursion, larger motor structures and higher power handling allowing them to play louder with lower with reduced distortion.
The V.2 series of ultra-low frequency transducers satisfy both the hard-core boomer and audio expert with uncolored bass reproduction, impressive dynamics, proper tonal quality and bone crushing SPL. The new massive motor structure with increased linear excursions of 13mm to 14mm one-way and increased power handling provides the IDQ V.2 with an advantage in competition level reproduction. Anodized aluminum voice coil formers remove destructive heat from the voice-coil by radiating the heat to the extended pole piece, moving the heat efficiently out of the motor system through our vented cone system to lower power compression and insure you get the most out of your amplifier investment.
The IDQ V.2 performance is a result of sound engineering practice and give up nothing in the way of performance to the so called high output wide surround subwoofers. Just like a larger engine produces more useable power a subwoofer with more displacement produces more output. Displacement for a subwoofer is simply cone diameter multiplied by linear Xmax peak to peak (bore X stroke). Since very little of the surround of a long excursion subwoofer actually contributes to the displacement of the subwoofer their reduced cone diameter results in lower displacement requiring an increase in linear Xmax just to equal the displacement of the IDQ V.2 subwoofers.
This combination of innovative engineering and durable high-quality materials, including Image Dynamics exclusive Unisurround and MIP cone technology, extend the V.2's performance beyond the abilities of woofers costing much more. Combined with outstanding durability and low measurable distortion the IDQ V.2 has no equal at its price.
Features:
Voice Coils: Dual 4 Ohm
RMS Power Handling: 250 Watts RMS
Program Power Handling: 500 Watts RMS
Xmax: 13.2 mm
Sealed enclosures: .25 - .50 Cubic Feet
Ported Enclosures: .75 - 1.0 Cubic Feet
$175
The boxes are 20" wide x 15" tall x 5" depth top/ 7" depth bottom
This series of amplifiers is specifically designed to deliver 1-ohm mono loads, ideal for powering multiple voice coils in parallel or for running 4-ohm loads where maximum dampening and minimum distortion is desired.
• Solid Brass Nickel-Plated Terminal Blocks – This feature allows for better conduction of electricity and improved current flow. Using this type of metal also protects against corrosion.
• Cooling Fan(s) – To ensure smooth and efficient operation, special cooling fans improve heat dissipation to keep the amplifier’s temperature at a suitable level.
• Bridgeable
• Tiffany-Style RCA Jacks
• 1-ohm Stable
• Hour Meter
• Onboard Crossover
• Subsonic Filter
• Bass Boost
• 4-way Protection Circuitry
• Beveled Clear Acrylic Protective Cover
160 Watts x 4 @ 4Ω Stereo
290 Watts x 4 @ 2Ω Stereo
480 Watts x 4 @ 1Ω Stereo
500 Watts x 2 @ 4Ω Mono
825 Watts x 2 @ 2Ω Mono
960 Watts x 2 @ 1Ω Mono
$325
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Absolutely. I have an IDMAX 12 in a 1.65 cubic sealed box on 900 watts and it sounds great. You won’t be disappointed. Pull the trigger.
23
I could swear Ive seen those years ago. I wouldnt waste money on it
112
9K
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
randyrsx
randyrsx
Behind you!
bumbabeef
    Jun 1, 2024
    May 31, 2024
