SOLD FS 15" Tc Sounds 3000 D2 - Barely Used
Decaf
Coffie w/o the Hype
1. Product:
15" Tc Sounds 3000 DVC2
2. Specs:
1000w rms conservative, roundwire, 3" peak-peak, strong motor, detachable
Qts0.280
Qes0.31
Qms5.440
Fs17.8hz
Re4.14
Le6.12 mH
Dia325mm
Vas197.05l
Bl27.9 Tm
Spl87.34dB
4 wide bolt pattern on top plate + perimeter 4 bolt pattern
3. Description/Condition:
near mint, no dings/scratches/dents/rust/paint chips... cherry!
4. Price: :
300shipped detached
OBO
Paypal Only
No trades
5. Pictures:
I would say this sub is better than hdc315 and i have owned both!
These do very well in a smaller box 3-4 instead of 4-5 for hdc3.
These have 10" spider compared to 7 something for hdc3 also dont let the smaller motor fool you i think the motor has copper in it compared to nothing but china steel in the konaki motor. and the thick top plate makes it almost as or heavier than an hdc3 which is alot of ferrite less steel.
These sound so good you just want to listen to all your songs again to see what they sound like with a nice sq sub. It will play anything you can throw at it and is very loud on stuff that some subs cant get loud on like certian rock notes the tc3k will just beat them out hard but smooth.
hdc3's are good too and can me made to sound great with the right box.
power handling i would say is similar but almost give the tc3k an edge and i think the tc is more efficient unless your really throwing a ton of power .
what would the price be for local pickup
Are you sure no trades?
yep, need to pay bills
Hey I'm kinda new to tc sounds
How does this compare with a hdc3 15
As far as loudness and sq, let me know I'm interested in this sub, thanks
id rather have this, aq likely will get louder but thats because its an SPL sub mainly and its soft parts are more geared towards 45hz+ bass
the tc is a wonderful mutil use sub, there are few things it cant do, its very unforgiving and accurate and will play exactly what its told to
well said... i think alot more design went into the tc 3hp motor and matching soft parts
with it being a huge *** copper coil it soaks power and lows are its middle name
270 picked up in dekalb, illinois
are you the original owner? Is this the older tc sounds or the newer one? i think there have been a few different tc3000s with slightly dif t/s specs
pm me so i dont forget about this
its an early tc3000 from what i can tell
im the second owner, first had this used home theatre on 300w amp in 4cuft sealed
i used it for 2 days on ~800-900w in 3.6cuft@32ish and my car got broke into, so i took it all out (they couldnt remove the box/amp/batt... too heavy and connected all together)
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
4
659
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
6
Decaf
Coffie w/o the Hype
Decaf
Northern Illinois
Decaf
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
