Ford OEM Audio upgrade help for a noob.
  • 1
nondem
I've got a 2017 Ford F350 Super Duty Crew Cab w/the Factory Sync 3 system. I don't have the Sony Premium sound system but it is the 8" screen version that has 4 door speakers, 2-tweeters in the A-pillars along with a Center Dash speaker. I'm not sure if the center speaker plays anything beyond the phone/navi audio. For that matter - I don't know much at all about this system - where to find the actual specs for it or specifics on how it is laid-out.
Could someone point me to some some info and/or good sources for what my options are for mild upgrades to my factory system?
I have ordered replacements for the front and rear doors:
Front - Kicker 43CSC6934
Rear - Kicker 43CSC674
These aren't top of the line speakers obviously - but better than OEM for sure. They are pretty much plug-and-play w/the wiring and adapters that Crutchfield include specific to my truck.
The reviews I've read on these seem to indicate they sound reasonably good with the just the factory head-unit driving them. I'll be installing them this weekend so I'll be able to tell how they do soon...but I'm interested in upping the power to them anyway.
As many of these systems that are out there - Ford produces 88 trucks an hour at the Super Duty factory - I don't find a lot of specific information on what i'm dealing with and what my upgrade options are considering I want to keep the OEM head unit.
In addition to upping the power to the door speakers - I'd like to maybe add eventually add a smallish sub behind the backseat but that is a maybe - depending on how the 6x9s sound.
I found a 4 channel alpine amp that accepts low and high inputs but I am hoping to avoid cutting a lot of wires and grafting something in using the high-level inputs.
I remember seeing a plug and play upgrade for the Sony AMP that comes w/the premium sound system but I "think" this one doesn't have a seperate amp.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
812
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
nondem
nondem
Tallahassee, Fl.
nondem
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
