Ford F250 Custom Center Console 13w7
  • 2
This is my first build log on this forum so bare with me for the next week or so. Im building a center console in an F250 to replace the factory flip-up seat. It will house the JL 13w7 as well as display the JL HD 1200/1. Just finished up framing the box, I'm still undecided whether or not to fiberglass the bottom of the enclosure to the contours of the floor or lose some airspace and close it in with MDF. Give me your thoughts?Here are a few photos of the before shot as well as the outer frame i constructed today. I'll keep you updated tomm when i move a little farther on the enclosure.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
673
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
GiovanniCustoms
GiovanniCustoms
Central Florida
04murdalanche
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
