Ford f250 2005 sub and amp help
  • 3
I have an '05 and there is almost no room, if he has a power sliding back window even less. Under the back seat is about it if he doesn't have a fold out rack. My future sub will probably be a fiberglass fab in the center console, unless someone makes one. Anyone seen one?
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
885
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Kylep000
Kylep000
Texas
Kingstroker
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
