First try at repairing an amp.
  • 6
goose5741
So I'm trying to repair an amp for the first time. Its and older Lanzar 1200rms@1ohm amp, thats all i know about it, don't know model or anything. It broke a few years ago, still worked but started blowing fuses (30 amp ones on the amp itself) whenever it tried to draw any significant amount of power, gains were set properly with a DMM (well I guess thats not neccesarily properly, who knows if it clipped or not at the 1200wrms i had it set for, never scoped it).
Anyways, i opened it up today, nothing is visibly burnt. And the only thing out of the ordinary was that 3 of the power MOSFETs clearly had been replaced and are not identical to the rest of them. Need to check data sheets if i can still read a part # off of them to see if they are equivalent to the rest, but i'm guessing they are in some form becuase the amped worked perfect the first 6 months i had it.
Any ideas where to start? or what could be wrong with it?
Nevermind on the FET's being different, I was wrong, those are diodes that are supposed to be there, the TO-220 package tricked me into assuming that all of those were supposed to be FETs
Indeed. You are way too inexperienced. You need to learn from someone. I got shocked by a Memphis 4kw (while checking for a hot part) because I wasn't paying attention. Lucky for me, the amp was not running, but it still shocked me and it hurt bad. You need to send that amp to someone who works one them instead of playing around with something that will either hurt you, or blow up after you think you've fixed it.
How do you do that?
Easy way is to hook up a ground, and put a voltage on the remote turn on lead (NOTHING ON THE +12V LEAD!). Let it sit for a couple seconds, and you should be fine. Use a DMM to check for voltage between the +12V line and GND. Once the voltage is below 2-3V, you should be fine.
x2, that's exactly what I do.
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
The best thing you can do is make a solid plan. This way you won't be spending money twice and having to keep going back in add or replace parts.
27
3K
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
96
goose5741
goose5741
DUBUQUE, IOWA
Mass Car Audio
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
