Fiberglass How To's
great thread!!
were can i buy fleece or whatever i can use to make my shape? i would like to just buy local so i dont got to order
i want to try and my a custom center council any links or any help?
what will i need to do just cover a fully made box. im new to all this. thanks for the help.
youll need enough fiberglass and resin to cover the enclosure enough times to make a difference. use either the mat or the cloth type fiberglass. and the generic resin should be fine. experiment using the resin and applying the fiberglass on a scrap piece of mdf so you can get a feel of how to do it. and then work on your enclosure.
I have over 100 pics of the process here that you might find helpful:TT Audio mk.II
how did he get the top mdf assembly attached to the back wall of the box which was only fiberglass? since he cant put screws into it, how did he hold the top on?
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
6
MikeofTulsa
Moderator
The one and Only!
MikeofTulsa
Tulsa, OK
butterMilk
