Fiberglass center console w/ 12"
today is the final structural build day...going to glass all the rest. after that its just bondo, sand, paint...
A 12’ sub firing up/out/forward and only 36” from your head
You are only going to hear the mechanics’ of the sub working not the bass
The bass will sound better outside the vehicle than in the front seats
I see this every day with crazy fiberglass builds and woofers pointed in all directions all for looks and no performance
Do mean to “DIS” I can see you have done a lot of work
Just giving you some input
A 12’ sub firing up/out/forward and only 36” from your head You are only going to hear the mechanics’ of the sub working not the bass
thanks..i did nearly the same setup in another avalanche just not out of fiberglass and it sounded just fine..if i go sit in the cargo area of my car with the sub...all i hear is bass..
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
6
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
732
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
546
Audio Control ESP 3 is the way to go ..if your wanting to do a quality center channel setup ...
7
terra
terra
Yes
terra
Dan Medina
    Jun 17, 2024
Doxquzme
    Jun 15, 2024
