Enclosure question for single 12" Fi Q
  • 5
Port area seems slightly on the high side at 20 square inches per cubic foot. But anything less and I'd be pushing over 90ft/s of velocity through the port at tuning and that will create port noise. This design is already 80ft/s which is pushing it.
Too much port area narrows the bandwith and loses cone control. 20 port per cube sounds overly excessive.
It seemed a little excessive to me too but that was the only way I could get a 33hz tuning while keeping port velocity around 80ft/s, which is still a little on the high side I think.
When you try to find the feet per second for the port noise, you normally input the amount of power its getting. However for example a 2k amp, you dont put in 2k in the signal / power section because there is impedance rise, its more proper to put in a gauged amount of power after box rise. Or else your rear air velocity will always go through the roof excessively.
When you try to find the feet per second for the port noise, you normally input the amount of power its getting. However this does not mean having for example a 2k amp, you dont put in 2k in the signal / power section because there is impedance rise, its more proper to put in a gauged amount of power after box rise. Or else your rear air velocity will always go through the roof excessively.
Well I'm running a T2500-1BDCP at 4ohms currently with a birthsheet saying 2200W @4ohms. So I'm putting in 1500W in the signal section. Pretty sure it's pushing 1500W since it's the constant power version of the amp. I'm trying to tweak it a bit in Torres but I'm not able to get it below 17-19sq inches per foot :/
My FI Q 15 back then was in a 4 cubic feet net box tuned to 32 hz, with only 52.5 sq inches of port area so around 13 port per cube and it had no port noise at all. It played very low and linear blending to the upper hz range as in you hear it faintly but its there. However for metal, i'd suggest a different sub like an SSA Xcon, switched from an FI Q 15 to an ssa Zcon 12 and sound quality(to my ears and listening preferences) was astonishing. Tuned to 33hz and it hit everything loud and clear from up high and down low.
Well then I'm not sure how to get this box to a 32hz tuning while keeping the port area per foot down below 16 and the port velocity numbers under 100ft/s
I can shrink the width of the port but that's just gonna up the port velocity alot.
I dont think you will run into any port noise issues at all. I've ran with much less than optimum port area, got a pretty true to tuning sound with full sounding lows and no audible port noise at any given frequency.
K after toying around with it a bit I think I might have found the optimum box, minus the 101ft/s port velocity winISD is reporting me. But by shrinking the port from 3.5" wide to 2.75 and shortening the port to 34" from 44" I end up with exactly 16 square inches of port per foot and approx. 40 square inches total with a tuning of 32.6hz. Sound pretty good to you?
It doesn't actually seem much different from the box it's in now but the port is 1" wider and has 7 more square inches of port vs the box it's in now. According to Torres the current box is 2.8cuft net tuned to 26-27hz with only 9sq inches of port per foot (gross) lol. So this new one should hopefully be a pretty noticeable difference.
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
1.25 NET cubes. You have to add the sub and port displacement to the box. I'm guessing that you will be around 1.7 net before sub and port...
7
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
gamehawk55
gamehawk55
Victoria BC, Canada
gamehawk55
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
