SOLD Eclipse, Kicker, Zapco, Sounddeadener, Carpet
CrazyKenKid
Canada
For Sale Goods: All Prices are SHIPPED PRICES, AND are !!OBO!!
1. A piece a of carpet I have just laying around collecting dust, this i will give to the first buyer for free if they want it
2. Zapco RM-6H.130 - SOLD
3. Orion 4002 - 150$
4. Kicker SX650.1 - 160$
5. Zapco I600 - SOLD
6. Eclipse DA7122 - 275$
7. Sounddeadener - SOLD
Specs:
1. I do not know the dimensions because I can not find a tap measure at the moment
2. Zapco RM-6H.130
Impedance: 4ohm
RMS: 60 (peak 120w)
Frequency: 65-5300Hz
Sensitivity (1W per 1m): 92dB
3. Orion 4002
RMSt: 100 x 2 @ 4 Ohm
Peak: 200 x 2 @ 2 Ohm
Birdged Output: 400 x 1 @ 4 Ohm
Signal To Noise Ratio: 100 dB
Frequency Response: 20 - 20khz
Built-In Crossovers: Yes
Ohm Load Stability: 4 Ohm Bridged
Low Level Input: Yes
Built in Cooling Fan: No
Bass Control Knob: No
Dimensions: 18.4"L x 10.5"W x 2.3"H
4. Kicker SX650.1
RMS: 325W x 1 @ 4 Ohm
Peak: 650W x 1 @ 4 Ohm
RMS: 650W x 1 @ 2 Ohm
Peak: 1300W x 1 @ 2 Ohm
Signal To Noise Ratio: 100dB
Frequency Response: 20-200Hz
Bass Boost: 0-18dB
Built-In Crossovers: High and Low
Built in Cooling Fan: Yes
Dimensions: 16"W x 2-1/2"H x 10"D (11"W without endcaps)
5. Zapco I600
Mono Output @ 2 ohms: 1 X 750 Watts MAX
Mono Output @ 2 ohms: 1 X 610 Watts RMS
Mono Output @ 4 ohms: 1 X 430 Watts RMS
Remote bass boost control included
T.H.D. Distortion with 22k Filter
Frequency Response: 10Hz - 230Hz
S/N Ratio: >85dB
Dimensions: 13.5"L x 10.75"W x 2.25"H
SymbiLink" Balanced Input
Balanced line (speaker) input for OEM integration
Unbalanced RCA input
12dB Bass EQ at Full/LP at 45Hz
Variable electronic crossover
Single Channel Class D Amplifier
RCA Inputs, Symbilink inputs, or speaker level inputs
Remote Bass Level Control with Wired Remote
Top Mount System Controls for Easy Access
Highly Efficient Compact Design for Easy Mounting
Switchable Bass Boost Circuit
Variable Crossover
Subsonic Filter
6. Eclipse DA7122
Amplifier: Mono Channel
RMS Power at 4 Ohms 500 W x 1
RMS Power at 2 Ohms 1000 W x 1
Frequency Response 4 Hz - 3000 Hz
Signal to Noise Ratio 120 dB
THD at Rated RMS Power 0.01 %
Low - Pass Frequency 50 Hz - 200 Hz
High - Pass Frequency 50 Hz - 200 Hz
Other Features
Input Voltage 10.8 volt
Dimensions 16(L)x12(w)x2(H)
B-Quiet® Extreme http://www.b-quiet.com/extreme.html
it is 50ft long UNTOUCHED!
The Story:
1. Just hanging out collecting dust
I upgraded my 5.25inch to 6.5inch. These never seen power to them
3. Orion 4002 - 155$
Used it once to power 2 6x9 pushing 80rms to each one.
Purchased this one as an as-is one. turns out the part costed 35$ to get a new one so i got it repaired and now have no need for it.
Got this from a buddy then turns out i can not use it because i did not notice it is not 1ohm stable derrr on my part for not paying attention. Does 750rms as a rms burst rating. Instead of a huge “when lighting strikes” rating like most other manufacture use. What this is a rating of what the amplifier can produce still clean in a burst situation, such as dynamic parts in the music. The amp is 610rms with a clean burst of 750rms clean. (Robert at zapco, Mar30 2009) Yes I e-mail zapco what they meant by 750watt which is printed on the box and that is what Robert Rugani replied to me!
Got this just to try out against 2 sae 1000d amp(strapped 1800@2ohm)! suprizing it did the job quite well but I have no need for it now! (some ppl say this puts out 1800rms at 14.4 volts i say around 1750rms but then agian who am i to say what it does)
7. SounddeadenerI purchased 100ft and only used 40ft so i got some extra! When i purchased it, it arrived in 2 box each with 50ft in it!
Pics:
1. A piece a of carpet (free with purchase)
5. Zapco I600 - 150$
7. Sound Deadener - Sold
no more deadener canadian bro? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
ya sorry man i jsut sold it within the first couple of hours to a guy over in BC lol!! sorry man!! but ya check out that site that i have listed there they have great prices and better yet they are a canadian company so shipping is CHEAP man! plus i think they are on ebay also with better deals!! check it out man!
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
909
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
CrazyKenKid
CrazyKenKid
Canada
CrazyKenKid
