Dual alt brackets for F150 4.6L
Let me take a pic real quick, but my whole engine sits way back. Did you like the mean green?
And for an //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif, I plan to be running 3000w at least but no more than 2 AQ 2200Ds. So I'm kind of wondering exactly what to get here.
I dug the mean green. With a crunch gp3000d I had a yellowtop up front and two pm d3100's in the back, at idle with very bass heavy music (bass mekanik crap) the lowest I got it to drop was 13.2, that was rarely as well, most music 13.7 was the lowest I saw. At speed I'm sure it wouldn't have had much drop at all.
I don't think my engine sits way back, maybe your year is different.
Maybe you can see how far back it sits
Here's the alt hiding
pretty close to how mine is, take off the intake and its an easy swap, 15 mins //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I can't imagine that with an 8 inch lift. Btw how does the 4.6 do with that lift?
Talk to Jake Ballard im sure he could come up with something. ballerd09@yahoo.com he is also real quick at shipping. Took him 1day to get my h/o alt to me:D.
I shot him an email.
I did 4.88 gears when I did the 37's so it does fine. Comes out of OD on hills on the interstate if you try to run 85, if you do the speedlimit though it holds OD fine. Plenty of power in 4-low for just about anything.
And somehow it gets the same gas mileage it did when it was stock //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Hmmm. That's strange. Maybe it's because the ratio, even though you changed the gears, is lower.
Sounds good man just tryn to help get Jake out there he has great customer service & as soon as i get my alt installed i will deff give a nice review:D. Just waiting on some wire and just got over nearly almost 24hrs worth of food posioning:(.
What size is your alt?
It's a 250amp alt but he said depending on electrical will do 280 at 2100rpm and 180 at idle:D. My electrical 3 batt's , alt , 3 runs of 1/0awg , BIG 3 & im still not done lol.
That sounds like what I'm doing. Do you have ground runs to the back?
yeah I got from front batt to 2nd batt to 3rd batt all batt's also grounded and fused(fused cause just had em lying around haha). Also the alt will have a 2nd ground 1/0awg also. That's another thing jake does on the back of his alts there is a threaded hole to do a 2nd ground to out of 1/0awg you don't have to but it is a smart idea to plus i'll have the BIG 3. all 300amp anl fused:D.
If you can get an alt that does 180 at idle and 250 at speed with the power you are going to run I personally wouldn't worry about a 2nd alt
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
173
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
481
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
951
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
900
Buck
little alien on campus
Buck
Inside of a pyramid
Buck
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
