Dsp
heyhi1
nyc
Im looking for a deal on a dsp. I need 4 channels and 4v output minimum with a budget of 300.
Bit 10 budget 250
Rockford .3 budget 250
Masconni budget 300
Mini dsp 6x8 budget 200
Any helix 350 or less
Jl audio twk 300
Or similar dsp , nothing buggy or having problems. Yes i mnow the Rockford is buggy
Pm me please. I can send payments thru paypal
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
912
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
680
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
heyhi1
heyhi1
nyc
drewcula
