dsp suggestions
  • 4
psylo535
tampa,fl.
Looking for a dsp to run 2 way active components and subwoofers all while keeping the factory head unit. A few things that would be nice :
small in size
high level inputs
smartphone control ( dont have a laptop but I suppose i could buy a cheap one if needed)
Around $300 or less
An audison big ten is $350 and requires a computer. A pioneer deq-s1000a is $150 and runs through an app. Both have de-eq so I think both will get the job done. I’d personally prefer not to have to buy a laptop
I agree about the laptop. I already have an ipad and have no use for a laptop other than this. I'll take a look at the pioneer, thanks for the reply
DSR1 as well.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
701
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
466
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
437
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
psylo535
psylo535
tampa,fl.
psylo535
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
