Dsp 408 sub configuration
  • 5
JulesH
29
VA
For those with a dsp, how do you set it up with a single mono sub? My amp has the 2 rca inputs. Should I use 2 channels on the dsp to go to the 2 amp inputs? Or some type of splitter? The whole mono thing is confusing to me.
Use both RCAs to your amp and link the two channels on your Dsp.
How do you like that 408? Are you getting any hissing or other noise from it? I heard people have problems with that.
Thanks for the reply.
I dont have any noise but it is a common problem in the forums. As a last resort some people have used an inverter and the ac adaptor. My electrical is squared away, grounded at the battery, power and signal wires on opposite sides... but even with all of that some still have noise with the dayton.
How are they when it comes to sending the unit in for repair/change have you heard? I sent back an amp that was hissing to Sundown. They sent me a new one and no noise.
No idea, sorry. Mine works fine. I think the noise is a design issue that affects some cars.
Dayton has a pretty good reputation as does Parts-Express even with RMA's from what I am told.
Parts Express is a pain in the ass if your shipping outside of the US.
They don't assign a broker for the shipment so its up to you to arrange everything.
It never used to be like that but I ordered some carpet and vinyl wrap in December and it took a month to get it because of the broker issue.
Unfortunately for those of us that do not live in the US its one of the only places to get some materials.
I'm hoping its a Covid thing and it changes when and if we ever get back to some kind of normal.
So a heads up, most of the issues with the dayton 408 in my research resulted from using the external volume know with the dsp. It was a known issue, and dayton has stopped producing them. Just use the volume knob with your amp instead.
Thanks for the info. I was wondering why I can’t find the remote for sale. That’s a bummer. I need to be able to switch presets quickly.
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
874
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
660
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
JulesH
JulesH
VA
GTSQ
