Down-firing in a hatchback sounds good
  • 5
XHiFiX
Today I decided to experiment with a downfire sub setup. I had an extra box (1.25cu ft) sitting in the garage and I just cut 2" length pieces of wood to make feet for it.
I've currently been running 2 Pioneer champion series 12's in a 3 cu ft sealed enclosure. Each one is the D4 version and they're series/parallel wired to a RF T3002 for 702wRMS @ 4 Ohms bridged.
I took one of the Pioneers to use in the downfire enclosure. Wired the coils in parallel for 2 ohms which would let the T3002 put out 923wRMS bridged.
Here, I corner loaded the box in the hatch.
Result - the one 12 in the downfire box sounds better than my previous box with the two 12's firing to the rear. There was noticeably more depth and 'rumble' and the bass sounded more natural. It was still loud but the sq was better.
So now I'm interested...what makes down-firing work better? Does it reduce cancellations? Why do they usually work better for vehicles with open cabins (trucks, hatchbacks) instead of cars with trunks?
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
893
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
873
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
12
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
XHiFiX
XHiFiX
Jacksonville, FL
x1le
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
