Does it matter what gauge wire i ground with?
marquisbrah
I have two amps strapped running on the same 1/0 power wire, but only there is only enough 1/0 ground wire for one amp. Can i just use 4gauge wire to ground each individually, or can i ground one with 1/0 and the other with 4? Ill be getting a power distributor to run both 4gauge wires to a single 1/0 if thats necessary. Thanks
the ground wire is very important. look at how many problem occur b/c ppl don't use the proper ground, buzzing noise, ground loop, poor sound quality etc.... don't skimp on your ground.
basic rule of thumb is your ground should at least match the input gauge for power. using an improper grounding gauge is like using a 30A inline fuse for an amp that draws 60A...it ain't gonna work
ive seen saz3500 run off a 30A fuse //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif go to a meca event //content.invisioncic.com/y282845/emoticons/boink.gif.91933e72f927f2cefc79aff02573090c.gif
maybe for burps but a 30A fuse isn't going to hold up for a daily
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
548
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
marquisbrah
marquisbrah
fresno cali
ultimate157
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
