Does BIG 3 need fuse?
I've always known to fuse it, but as of late, people have been saying not to fuse it, because if it blows, your alt won't be charging.
So for the sake of it, I'd fuse it. Rather be safe than sorry
and the fuse solely depends on the wire gauge you use. I presume that you're using 0 gauge, so yes 250a would be fine
As long as you have easy access to the fuse and carry spares or still the same outcome that you're going to be stuck wherever you are because of a $10 or less fuse couldn't be replaced. I suggest a 300A for a 0ga right next to the battery from your alt.
if u leave the factory wires like i always do ur alt should still charge, the fuse would be to protect the bat and alt in the case the wire is cut or burnt and shorts out
Awesome thank you guys for all of your help. So going off of what "shauncox26" said, should i also leave the factory wire from alt to battery and just add my 0ga to it or replace it completely?
No fuses on any of my big 3 setups..Ive never had any issues up to date.Even on the daily around town vehicle.But 0ga/250-300max
My big 3 is done in 4/0 welding cable without a fuse and I have yet to see an issue. But I should probably be using one, the factory uses a fuse from alt to batt, so we probably should be too.
Not using a fuse will not cause any immediate problems, but when your wire get's cut/pinched/corroded/etc and ends up shorting out to the chassis and causing your battery to explode you'll regret it. It's like saying "Well I've been driving for years without a seatbelt and never had a problem."
If you're competing and looking for every 1/10th of an amp you can get from your alternator then by all means disregard the fusing. But if we're talking about a daily driver you absolutely should be using fuses.
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
330
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
980
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
947
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
ObTechAudio
ObTechAudio
Provo, UT
bubbagumper6
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
