Does 1 Hertz equal 2 Pioneers
Do they not make the 12tw5 anymore? That airspace would be perfect for a 12tw5 or the new alpine r2 10 shallow.
I only see the JL TW3 series and the TW5v2, I don't see anyone seeing a TW5.
But that circles back to the original question in essence: does 1 sub like that give better results than if I maybe pick up 2 DD SL600 10s that are happy in a .75 ft3 ported box, which would be 1.5 ft3 for 2 in one I think.
Depends. Alot of the time running 2 subs instead of 1 can lead to less than ideal airspace. This often times cuts down on low end response and makes the box naturally peak at a higher frequency.
But 2 subs have more cone area and will naturally have more ability to move air at lower frequencies.
Assuming the fs of the 2 subs is fairly low and the box is close to optimal I'm gonna say that it will be louder and likely cove the same frequency range better.
But if the box is much too small you will lose bottom end. This is where modeling software comes into play especially if you can model in you vehicles cabin gain
Cabin gain is what makes sealed boxes work since sealed boxes usually **** below 40hz. Luckily cabin gain below 40hz usually helps flatten the response.
Looking back at the post I do not believe that the sl610 will be happy in .75cube ported box, you will likely need at least 1 cube if not 1.25 to perform optimally
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
452
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
Zoko
CarAudio.com Newbie
Zoko
KCMO
winkychevelle
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
