dodge charger brake light working incorrectly
  • 3
Donks
CO, Ohio
i have an 06 charger. im running into a problem. ALL of my light work correctly when the headlights are turned of but when i turn on my headlights my driver left brake light doesnt work...im thinking its an electrical problem but the car is stock...i have no idea i've tried jumping wires and had no luck i dont want to get pulled over so im trying to find the right solution..please any input would help
Check for bad relays in the fuse box. Specifically your brake and headlight relays.
Sent from my Z970 using Tapatalk
thanks, but i found out it was the cheap a$s aftermartket led bulbs autozone sold me..they all work perfect after replacing them. thanks you guys
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
4K
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Donks
Donks
CO, Ohio
Donks
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
