Do L5's and L7's have the same cutout size?
L7's the only thing youve listened to? To me they sound nasty. My RE SE's hit SOOO much cleaner, and LOUDER off less power, And sealed up.
Not only are you an idiot, but you also fail to understand basic physics. The Kicker L7 is a pure SPL subwoofer. The RE SE is a pure SQ subwoofer. The RE SE is far more efficient and requires a lot less power. The Kicker L7 only shines in ported boxes. Basically, keep your opinions to yourself especially when they are so obviously irrelevant and wrong.
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
763
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
yo0123yo
yo0123yo
chicago
PV Audio
Decebal
    Jun 10, 2024
