Do I Need To Change Batteries?
  • 3
darita
I've got an 09 Civic Si with a 200W Kicker amp and 1200W AQ1200D amp. Just installed about a week ago, I've had no problems with lights dimming with stock electrical. I have a replacement Kinetic HC1400R battery ready to go in.
1. Should I wait for the stock battery to die or should I replace it now?
2. If I wait, how long will the 1400R sit on the shelf and be OK?
3. If I replace the stock battery now, should I save the stock battery and how long will it sit on the shelf without going bad?
I have already added enough weight with two subs in a sealed box. I'd like to just swap out the stock battery rather than adding another.
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
283
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
674
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
440
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
493
darita
darita
Sacramento
skylineTT
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
