Do I Need a Subwoofer, or/and an amplifier, and what kind???
First did you run real speaker wire you hooked up these really nice sensitive speakers.the stock speaker wire is always **** .if rms is under 100 rms per channel 16 gauge but good make sure ofc if over 100 12 gauge ofc
What kind of advice is this??
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
3K
That's an older sub, pretty sure it was made by Targa and its the Venom line. I remember seeing them back in the late 90's early 2000's if memory...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
139
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
105
coodood
coodood
St. Louis
Boomin_tahoe
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
