Do all channels output the same ohms?
  • 3
Danny Marz
CarAudio.com Newbie
14
I have a 5 channel amp. If I run 2 channels at 2 ohms and the other channels are wired for 4 ohms will all the channels output 2 ohms power or only the ones that are wired at 2 ohms? I’m basically trying to get my sub output higher by running it at 2 ohms  the amp I have doesn’t have enough power running to my sub
dash speakers —-> ch 1&2
front and rear door speakers —->ch 3&4
10” sub ——> ch 5
Sure, power output can be different.  It is determined by the impedance on THAT channel.
So if the amp is 70x4 at 4 and 100x4 at 2 + 300x1 at 4 or 500x1 at 2
Ch 1/2 would be 70w per speaker
Ch 3/4 would be 100x2 or 50w per speaker.
Sub would be 500.
Assuming all speakers are 4 ohms and the sub's wired for 2.
So there’s no way to wire a single voice coil 4 ohm sub down to 2 ohms? My sub is just a single voice coil 4 ohm kicker sub
I've had a few 5 ch amps in the past and currently on my 3rd one right now. What determines running a lower ohm load to your amp that will change impedances and more power is how you wire your sub and/or speakers for a final impedance. For instance: The sub ch on my amp is 250 @ 4 ohms, 450 @ 2 ohm and 600 @ 1 ohm. All these ratings are for 12.5 so it's underrated. My sub is dual 2 ohm. I have it wired to a final impedance of 1 ohm....wired to the amp and will make the most power from it that way. Pushing around 800-850 watts @ 1 ohm.
So to answer your question, your stuck on running that sub on 4 ohm....unless it was dvc then you would have more wiring options. I'd buy a dvc sub if I was you and sell that one.
negative
Might not be much of a factor though.  The 300/500 example above would only improve output by a couple dB assuming the sub's not already near its limit.  Could be less than that.
860
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
6
364
Which amp and which speakers? What crossover are you using? You may be fine so long as you never push the volume too hard.
12
Danny Marz
CarAudio.com Newbie
Danny Marz
n2audio
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
