Digital audio high current 2300 amp need info !!!!
  • 1
I've heard its pretty much the same as the audiobahn version. But it's got 2 top rails dual 2" fans and 2 analog voltage meters ( the ones with the needle that moves lol) its heavy as fu** probably 25 -30 pounds and a little over 2 feet long. It's a 2 channel. Just curious if anyone knows what these are worth it works great and pretty good cosmetic shape. I'll post pics tomorrow. Thanks in advance for any info
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
7
4K
mtx+psi-awsome
portal nd
mtx+psi-awsome
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
