Difference in Hifonics BRX, BRE, and ZRX?
  • 3
I'm looking into the Hifonics amps to run a pair of Sundown SA 15'S. What is the diffrence in the 3 models? I like the BRE 1600.1 and the BRX 1600.1 Both cost the same and do 1600x1 rms @1 ohm. What's the difference? Also I heard these amp's don't put out quite what they rate but the 1600 should still give me at least a clean 1400+ right?
If you can get it the BRE-1600 is the best of the 3. You may be able to find a BRZ-1700 for around 200 I think you will be good with either of them. I have ad relative good luck with there stuff I would say pretty close to actual rating if worried go with a size up then you can run it with more room
According to the Taramps site, there are three variants: TARAMPS SMART3 BASS 1 CHANNEL 3000 WATTS RMS 0.5 ~ 2 OHMS CAR AUDIO AMPLIFIER. TARAMPS...
I can hear the difference. A typical component system will have a superior tweeter and crossover, although I've noticed component crossovers are...
Just thought I'd quickly update this thread as it's been a long while since I promised an update, I finally checked the AC output of the speaker...
23
6K
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
HoovaDeuce 82
Ft.Worth, TX
Jeffdachef
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
